ORIGINAL: Doug Andre
Guys,
Try not to sweat the maiden flight on your ships. The flight characteristics are so friendly both on the ground and in the air. You will be amazed.
I found no tendency to tip stall anywhere in the envelope. The flaps are super effective and do not really upset the plane when deployed .
The specified elevator throws will be a little much for scale flying but fine for test flying. Even ground handling is superb with no tendency to tip up on the nose. I expected a wicked torque reaction on takeoff but experienced virtually none.
I have flown many heavy warbirds that make you work for every flight but this one simply does not count. Just consider it a nice looking pattern plane!
Regards,
Doug Andre
+1
dave
