Redundant Receivers
Quick questions about setting up redundant receivers for the SD-10G. Iread the manual but Iam a bit fuzzy yet. Do I bind 2 receivers to the same Model number? What are the mechanics of this, transmit bind code and hit bind button on both receivers at once? Does this work for FHSS-1 and -3? How do the safety link numbers relate to using more than 1 receiver per model? Any lag time between the two? Example if Ihad 2 aileron servers on the left side, could the outboard be on receiver 1 and the inboard be on receiver 2? Or do Ineed something like a smart fly system to switch between the receivers?
Thanks!!
JH
