ORIGINAL: Rombaut
Hi Clint
About CG, yes, this first flights I'm using the same as the factory recommendation, front edge back 115mm of down wing. About mixes, just a little RUD-ELEV ( less than Amethyst) and maybe in down lines get a litlle mixed with elev...
About the speed, Is easy to go fast in F3A, everything is easier. For me is better and nicer fly closer and slower to allows the judge see all the schedule and I think that this plane allows you to make it.
Regards
Juan
Having looked at F3A to get slower and closer - for -probably 25 years -I gave up - In studying the current winning styles - the maneuvers are as big as IMAC stuf (or even old TOC patterns in some cases) and I see no trend amongst the "winning combos " to change this.
Not sour grapes - it simply is what it is.
