RCU Forums - View Single Post - NTC3 Light In The Rear End
Old 05-04-2012, 08:05 AM
ZStein
ZStein's Avatar
Default RE: NTC3 Light In The Rear End
Yes, that is correct. With all wheels off the ground, if I turn one wheel, doesn't matter which, all wheels turn in the same direction simultaneously! If I hold one rear or front wheel and turn the other front or rear, the non-holding wheel will rotate in the other direction, but its tight. So is it best to leave it as is?
