RE: Cleaning Solutions
Go to Walmart in the soap section ( probably other stores also ) and pick up some " Dawn Power Desolver ". Close any openings on your engine then spray the areas you want to clean, heads, muffler etc. ( it's a gell when sprayed ). Let it soak for a few minutes then use a brush ( tooth brush works good ) to scrub it a bit. Then hose it clean with water. Do Not leave it sit long and be sure to spray it all off good. It works great, might take a couple applications but it WORKS !!!! ENJOY !!! RED
