RE: 5 Blade conversion and V Bar on Tubine Hughes
Jan,
3 servo ccpm conversion on the JetCat mechanics is very simple - pm me your email address and I'll send some pictures over.
Your biggest change will be that your JetCat system will need to be altered - the gearing is correct for 2 blade but not for multi.
You are currently running 1280 head speed and you will need to get it changed to a maximum of 998 - simple gear conversion at JetCat.
I would also suggest have ing the Twin Gear drive fitted at the same time to spread the increased loading - normally at no charge.
Again, send me a pm if you need more detailsof the changes.
modtron
Oxford UK
