ORIGINAL: PetRock
The Velineon will fit if you take the black plastic endcap off (it just snaps on and off). Another option would be a
Tacon 3660 3500kv: it's a bit longer and has a wider rotor than the stock motor... the KV is almost identical so the top speed will be almost the same: but it has a
lot more torque: accelleration will be very noticably better. And it's less than $35 new!
Do traxxas 32p pinions fit on the tacon 5mm shaft?
If not What 32p pinions fit?
Will I lose any room and not be able to run a 16t because of the larger shaft?
Is the tacon that much better then the hobby wing ezrun?
