RCU Forums - View Single Post - Once on step plane whips around and dunks
Thread
05-18-2012, 02:09 PM
4
Taxus812
RE: Once on step plane whips around and dunks
I measured the angle (incidence?) using a digital angle gauge. With the top of the float at 0 Deg I have Aprox +2 deg at the bottom of the wing (flat bottom trainer) and on the horizontal Stabilizer. I tried moving the floats forward to see if it made a difference (no difference).
<o
></o
I also tried to stiffen up the floats by adding some cross wires (eliminating flex). It did stiffen them all up a lot but no real improvement in takeoff.
<o
></o
I did a LOT of taxing and watched what happens. This is what I think is happening is its not tracking straight in the water sloshing left or right. Unconsciously I am using a lot of rudder to correct the drift. When I get up to speed and start to break water it was WAY too much causing me to tip one float in (then spinning out.).
<o
></o
I may try to add a waterrudder to see if thatwill help. My gut says the floats are just too short and it will never be as clean as it is shown on the video.
Reply
Like
Taxus812
View Public Profile
Send a private message to Taxus812
Find More Posts by Taxus812
View iTrader Profile
