Car Trouble
Finally a problem I cannot figure out. 2001 Olds Alero, loaded, 3.4L V6. 107K miles. Ran perfect yesterday, started fine etc etc, but all of a sudden today it will crank over like crazy but not start. Checked spark, can hear the fuel pump start up fine, no bad fuses or relays. Nothing seems loose. Tomorrow I will have my pressure gauges back and will be checking to see if it is the filter or a weak pump, but until then, any other suggestions? I have found many complaints about this but no solutions, and apparently GM won't recognize it as a defect. Hmmm.
