RE: Vertical Fin snapped off
Nothing wrong with the way the balsa is running at the broken section. The vertical fin on the avistar is stick construction not a solid sheet. Repaired a Tower Trainer with 1/4" tri-angle section to support the vertical fin on either side. Simple repair.
Jim
