OS 46AX Shaft Play
I recently ordered an OS 46AX engine and received it via UPS last night. There is a significant amount of end play (in and out) of the prop shaft.
When putting a little pressue on the shaft I can hear it rubbing on the back plate. I have two other OS 46AX engines and they don't have this issue.
This doesn't sound normal - not sure if it's the bearing or something else. In the meantime I will be returning this item.
