RE: Replacing Tornado S30 tires
Put you rims and tires in your oven at 350 degrees for about 10 minutes. The tires will pop right off, they'll be no damage or stuck tire pieces to the rim and you'll be all set to install new tires. You need to glue the new tires with tire glue.
