ORIGINAL: charlesp
as far as balancing if you read post 47 it should fly well. becouse I am just a little bit foward of that and will be moving it back
I would not think you would need 30 degrees on your first flight mine only moved .5'' up or down on the first flight and responded well I would start there with your low rates just MHO Good luck
I had already read it and I had no idea how to intpret it - and my top wings are epoxied together so I'm not going to look at the root rib side profile and try to guess either. That's why distance from leading is the best and unambiguous way to describe this, like plans do. However, I heard there were mistakes on some kits so I'm not sure which one of those is even right that I've been able to find. No two say the same thing and the Aero works kit is different than the kit I have.
