RE: BVM Rafale - flight characteristics
Guys,
I'm doing turbine run-ups today with my twin Super Eagle powered Rafale. I just installed a new set of Tams pipes. My concern is that the rear of the fuse seems to be getting unusually warm/hot! Due to the enclosed bypass there's not a lot of cooling air moving thru the fuse while stationary. I wonder if there will be that much more, though, even at speed in the air. I've never had a fuse get this warm before. Yes, there are now two turbines/pipes back there instead of one, so that could just be it, but would like some input from anyone out there that has experience running the twin set up.
David S
Just used a laser temp guage on the top of the fuse, 3-6" aft of the hatch. Within just a couple minutes of start, at idle, I'm getting temps of 176-200 degrees F![X(][:@] That can't be right!
