ORIGINAL: MAUS45
This very exciting news, but after looking at the instructions, for converting your HL tank to this new Clark system, it is not really plug and play. One still needs to disconnect several wires from there connectors and solder and or connect these wires to new connectors. Also have to build your own Tamiya Apple plug. This may be a simple task for some but not all. Still it is great to have another compatible control system that may work with Tamiya. Would be nice to know the price of the unit as well.
Clark shows a "How-to" build your own apple base a tamiya one would work just as well lmao
the other plugs are fairly simple to modify and im sure if you are able to undo a H/long tank and re-install all the cables that usually break free from there pads then you should be able to do that also
