Magnum building questions
Seafury,
Unfortunately I don't have a digital camera, but heres a picture of a canard linkage setup on a eurofighter, this will give an idea of what I mean.
I removed the outer tubes replacing the whole lot.
The ball links a mounted on the servo arm, one on the top of the arm and the other on the bottom of the arm, I bent the rods so they exit the fuse at the correct angle then mounted the control horns to suit, 90deg to the hinge line.
Don't hesitate to ask if you need any more help.
Cheers
Ossie
