RE: 12X Question (Glider Mode)
There seems to be various versions of 12X software out there. It is easy to duplicate the brake menu reverse stick option by using a couple of normal program mixes. Set up one mix of #SPO -> FPRN and another of #SPO -> FLAP. On both mixes, set the Offset to -170 or a lesser negative number (e.g. -140) if you want some dead space. Set the upper rate of either Pos0 or Pos1 to some value and leave the lower rate zero. In the Brake menu, you can still use the elevator compensation but verify the flap and flaperon rates are zero.
Allan
