RE: 14MZ Copy Function
You just copy the model to the transmitter or the memory card. The transmitter will then display the copy as well as the original. If your airplane is named "Spitfire", then the copy will show "Spitfire-1". The 14MZ does not have memory "slots" like the older transmitters had. It just has memory, and uses as much as necessary to save or copy your models.
