RE: Parkzone Ultra Micro Rtf and Bnf
I believe that you can. With my micros, they tell you to insure that you have the transmitter on when you connect the battery to the plane so you don't risk someone else binding to your plane. So, I think this is what you need to do.
1. Select an open model memory in your Tx. Then, turn it off.
2. Connect the battery in your plane. There should be an LED on the receiver/servo board that starts blinking.
3. Depress the "bind" button on your Tx.
4. Power-up your Tx. Wait for the receiver LED to go solid. You then should be bound.
