ORIGINAL: 91zulu
This is the Pica P51, look at the nose, then look at the TF nose. How ever the kit is a lot of work, a builders kit.
The Pica must be a huge amount of work. That would be why I still have not finished the one I started in 1998!!! That I have barely worked on it in years would have nothing to do with it.
Not alot of info on retract fitting on the Pica plan, you will most lilely have to do a bit of re-designing in this area to suit whatever retracts you choose.
I do believe the Pica will be a more accurate model when I eventually get it done.
