ORIGINAL: jknox
You have three choices of rudder setup. Direct linkage with servo rear, pull-pull with servo centered in fuselage, or pull-pull with servo up front under motor. I needed mine up front for weight distribution and I think it's nearly impossible to setup the pull-pull in the center anyway because the fuselage is too narrow to work in. I'm curious what servos you're going with. This was my first model to seal hinge gaps, but it was quite easy and the instructions state not to even think about skipping sealing the gaps.
Thats interesting on the rudder servo. I'll have to realy take a look at that. The Pro kit comes with the Hitec 82MG's. I hope they will do the job. I can always swap them out for the 5085's in the future. I'll post some photos soon. Thanks for the help. I'm planning on deflecting the surfaces before I glue the hinges in so I get the right gap. Then sealing the gap with covering.
