RE: PA Addiction X??
Next I glued on the motor box and test fit the Thrust 40 Motor. There is a clip on the prop side of the motor at the base of the shaft that is larger than the hole in the motor mount. I used my dremmel tool with a teardrop grinding tool to enlarge the motor side of the motor mount until there was no binding on the motor. Make sure you don't overlook this.
