OS 300 Twin Problems
Hello Everyone
I am having a problem with my O.S. 300 Twin, I go thru the priming procedure like the manual says to. Throttle fully open, choke applied and 2 counter clockwise rotation and the 2 clockwise rotation to prime the cylinders. When I spin her over there is so much raw fuel coming out of the pipes it is coating the tires on both sides. I gave the Air Bleed Screw a 1/2 of a turn counter clockwise which according to the manual should mix more air then fuel, I am using an EDI on board glow system to the glow plugs and all is working. I am at my wits ends with this thing, I need some advice and help on this one.
Thanks Morgan [&o]
