ORIGINAL: DualityRC
Okay, my update - Got it working, used AliShanmao's unflooding engine method then it started it, just have to fix the carb opening. Any idea on how to fix a stuck carb when I give it throttle? Thanks for your help too!
is it sticking closed or open?
if its sticking open....look at the return spring. The throttle servo doesnt actually close the throttle...it just releases its pull and the spring closes the carb. If the spring is stretched out...missing or something like that it wont work.
