ORIGINAL: rajul
Dave, could you post a photo of your cable connection from the computer to your DX7? You should disable the trainer mode. Although the DX6/DX7 radio is DSM (not PCM or PPM), the signal from the trainer port is tapped before any modulation is applied and is PPM compatible, and therefore works with AF5. There is nothing to set in the radio, but an AF5 JR stereo-to-mono adapter cable is required. Leave the DX7 switched off before plugging in the adapter cable. The radio will automatically switch on when the adapter cable is plugged into the radio. The radio will not work with AF5 if it is manually switched on before inserting the adapter cable.
Thanks, rajul. The secret was turning off the transmitter.
Does it say this anywhere in the manuals? I could not find it in the main manual or the USB instruction insert.
David
