RE: av8tor1977
I recently purchased a 32cc Stihl Four Mix Four Stroke that av8tor converted for aircraft use. Robert dos excellent work on these conversion engines. This one required a carburetor modification, as set-up stock, they lean out on the top end. So not only is the engine converted, it’s also set-up to go right off the bat! I’ll tell you, this is going to be a perfect engine for a ¼ scale Balsa USA Newport or PUP. I’ve bench run it and it swings a Xoar 18/6 with authority! I need to pick up a new tack so no numers, but this one is ripp'in my 18/6, might even go 19!!! Robert was also very helpful in providing technical info on the engine itself, and the carb modifications required. He has my recommendation to anyone looking for a good engine. And BTW, his prices are very reasonable, Mike.
