RCU Forums - View Single Post - APC Prop Constants...
Thread
09-11-2012, 02:13 AM
10
1QwkSport2.5r
RE: APC Prop Constants...
Quote:
ORIGINAL: airraptor
Ok here is the first result of my search on the net.
http://www.ae.illinois.edu/m-selig/props/propDB.html
http://soar.wichita.edu/dspace/bitst...773/t05031.pdf
http://dc.library.okstate.edu/cdm/si...id/2757/rec/14
https://netfiles.uiuc.edu/kotwani2/w...apers/FMFP.pdf
http://etd.auburn.edu/etd/bitstream/...pdf?sequence=1
this should be enough reading for you for now. It will explain how the constants were derived. Use this data to set up the calc with different props. then use a known prop in the calc on a engine that will run that prop at that rpm. then base other props on the same engine to get a general idea what the contant should be for that prop. this will work on any prop close to the same rpm as the ''known'' prop.
I came across most of those pages last night. I understand how the data is collected. Now to find the right data (prop constant) that works in Pé's spreadsheet.
Thanks for your time.
Reply
Like
1QwkSport2.5r
View Public Profile
Send a private message to 1QwkSport2.5r
Find More Posts by 1QwkSport2.5r
View iTrader Profile
