RE: Vortex SS no second gear
Thank you,
Ihave seen the videos for the repair of the trans and studied them closely. If i understand the repair i should not have to remove the engine to remove the trans. I ordered both gears 47T and 42T even though the larger gear appears to be un-damaged. If this becomes a regular occurnece as i fear it may. I will then order the entire trans to make field repair easier then i will always keep a ready running spare in my bag.
After replace the gears i will then check the mesh and adjust accordingly.
Thanks Sam and Nitro
