RE: Carb
No you have not missed anything as far as removing the carb its just the clamp screw on the side holding it in. Did you try to spray a lil wd-40 on the carb base and try turning slowly to loosen up the carb? Also will the engine run? You want want to try to remove it after it has raned a little and the heat should make it easier to turn the carb or try heating the carb with a hair dryer for a while and see if this will loosen it up for the carb to turn. Hope you get it worked out there should be nothing else left to hold the carb if you have removed the screw on the side of the car.
