RE: Catalina Kyosho PBY Seaplane - Advices
Hi!
My two Catalina kits did not have landing gear as the later kits had.
If you are not going to fly from water you could make your own landing gear (Semi scale) from 2-3mm piano wire that you bolt to the sides if the fuselage.Some reingforcements to the fuselage sides is necessary in that case though.
