RE: ESM FW D-9
I ended up cutting 1/2" worth out of each side of the cockpit kit to get the clearance. I covered the seem with aluminum foil tape and then repainted it. Im not going to modify the linkages etc for a cockpit kit....I'll mod the kit to make it fit since the plane has been test flown and changing positions of stuff now might cause more headaches.
I thought about lifting the servos with some wood, but then you also miht run the risk of the servo arms being hung up on the wing skin surface with the wing attached.
