RE: First R/C airplane flight and crash
If you really get stuck for a needle, you can figure out some kind of nipple to put where the broken part is, and use a remote needle. Maybe solder on to the existing threaded part that is in the housing or ? Fox has a remote needle for about $12 that is pretty good as Fox stuff goes. It is a bit heavy but can be bolted to the exhaust flange on most side exh. motors.
