RE: STRETCHING A HULL...IS IT POSSIBLE ??? Old Graupner Systems Cat build
Unless your using a cable setup to pull its not needed.That said if you wish to use a cable setup for steering then this rudder is ideal but for this cat with the flat transom you would need to manufacture a standoff on the transom to allow the rams room to work but it could be done using some box allumium section.
Mart
