RE: AR500 Thoughts ?
OK- - I did not go look - my last 5 is in a foamie just remembered the Y setup on aileron- anyway the four has an improved antenna system.
As does the 6 channel - The gear /aileron mix was the fix on those -as you noted -to get split aileron function.
