RE: Hangar 9 Fokker DVII
I forgot to mention that Ireplaced the axle with roughly same diameter rod but, stiffer. I cut it a bit shorter than the stock axle and it's working out well. It takes some fiddeling around with the internal collar to get it right but, mine seems to be working OK. After adding the collars to hold the axle still, it should work much better.
Looks like you guys have already figured all of this out but, wanted to share my solution.
RJ
