RE: ESM 50cc Corsair
Hill,
Go to dreamworksrc.com and buy some hysol. The stuff will bond and be stronger than anything in the plane. You can use it on the engine mount tube and I would use it anywhere you see a gap in the bulks heads, formers or anyplace you can reinforce. The stuff gives you long workng time and holds a bead, but once its hard, grinders have a hard time removing it. It's the stuff we use on building jets. If you are staying with the rudder / elevator cable system, I suggest you invest in a thicker cables. just my 2 cents and looking forward to your progress.
