ORIGINAL: mmflytie
Oh! my apologies. Right, the dowels to hold the leading edge of the wing into the fuselage. I drilled the two holes in the bukhead where I wanted them, then placed the wing on the fuse. Put my hand with a marker in thru the nose of fuse and made the mark thru the holes I drilled. Removed the wing and drilled where the marks were. Make sense?
You drilled the holes, then got the wings where you wanted them and then marked them.
