ORIGINAL: aframe2
Bushbarber, Yes I did everything you mentioned, and I did get the solid light indicating
a successful bind. One thing I did that might cause a problem was using a 4.8v receiver
battery. I am charging a 6v battery and will try that. Aframe2
Sounds good! I am sure others will chime in on this issue.
The only Binding problem I ever ran into was with an AR9000. I had Bound the Tx and Rx several times at my club field and at home with no issues. I tried to Bind at an airport next to a large metal aircraft hangar. It would not Bind. I called Horizon and they suggested I move out to the runway away from the hangar. I did so and had no trouble Binding.
