RE: Royal B17 build
The Spring Air retracts that retract side ways for 90 or 85 degrees can be used to retract forward for your use. Just rotate the wheel and strut 90 degrees. I've done it myself. You probably do not need the full 90 or 85 degree retract angle as one of the posters mentioned. Dan.
