Old 10-24-2012, 09:10 AM
countilaw
countilaw's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Mach1 question before upcoming build
Epoxy is better than contact cement because you can move the sheeting around to get it placed right. With contact cement, you get one chance to lay it down and get it right. However, if you like Contact Cement, Home Depot has a water based contact cement in quart cans. It works extremely well. It is white,so if you use it, put some food coloring in it so you can see how much you are applying to the white foam core.
There used to be a product out called, "Southern Sorgham" it was great stuff.
Frank
countilaw is offline
