RE: Gremlin help
Awesome stuff! I too am building for the Spring. I just dont feel right if there isn't one Gremlin in some state of assembly on the bench.
The only problem I am having is keeping the motor mounts from cracking. They are recessed flush with end of fuse and after a gallon or so of flights I see hairline cracks between the motor mounting bolts (always left side for some reason).
Can you fellas share your tips for strengthing that area? I hesitate to make it bomb proof as throwing a new mount on just takes a few minutes and does absorb stress of less than steller landings, but I would like to reinforce it a bit.
TIA
