Yesterday I spent almost all day in my work shop.
I start working on right wing side...
... and because everything fit well, after 45 minutes, right wing panel was in this stage...
I must just a little bit sand slots for wooden wing joiners...
...and then i put left wing side in position, for now without glue, just to check is everything OK...
Than I add glue...
After few hours I took off wing from the work table. In spar slots, on the bottom side I add balsa strips, same as I worked on upper surface...
... than sanding, and all transitions from ribs on spar was nice and smooth...
Next step will be to add 3 mm plywood plates between spars and ribs. This will be boring job...
While I was working in the workshop, Martin began to draw fuselage ribs... This is just first few ribs, of course here will be some changes...
Plan is to front fuselage section, be moveable, and when you take it down, on horizontal and vertical plates will have space for batteries and other parts.
Regards
Mirce
