ORIGINAL: invertmast
Adam,
Is there any place state-side that sells the Air Tak 2 spray? Could a light dusting coat of 3m77 be used instead?
Airtac 2 is available from Freeman Supply. If you google for "Airtac 2" you will see several other options.
If you mist a mold with 3M 77, lay in the fabric, and infuse you will end up with lots of little dots on the surface. This looks pretty ugly on naked carbon parts. This doesn't happen with Airtac 2.
