ORIGINAL: mpascual
First test on a production unit today:
GREAT ENGINE !!!!!
Include the engine mounting plate, RCEXL ignition, allen wrench, RCEXL standard CM6 spark plug,
My only guess is to include a 120 degrees spark plug cap. Better fit than 90 degrees supplied.
I've dismantled all parts to take pictures and check quality : awesome..
Needle bearings on both sides of con-rod, a custom WT1022 carb, very well made the intake mainfold , with two nipples, one for the oil from cranckcase and one for carb pressure pulses. Many interesting mechanical solutions, and NONE of the parts are from Magnum or a glow existing engine. All parts are designed from scratch. Like many others products of differents manufacturers ,they looks the same ....
[youtube]http://www.youtube.com/watch?v=gfiSpIg8pz0[/youtube]
Best regards
Have you looked at the rocker box, do the valves run in guides? If so, do they look like bronze, I'm currious as to how well the exaust valve will hold up.
