RE: Need some help: Fully custom build was fine, now having throttle range issues
hmm, it really sounds like bad batteries....i would bench test the input voltage going to the esc with a meter and see what the voltage drop is under load while its acting up. If the voltage stays at or near 22 volts then the batts are good, if it drops below 18 volts then the batteries are bad.
