Hi,
Endpoint hold does not have to be set to adjust the endpoints, you can do them by holding the transmitter stick all the way over and adjusting the endpoint while its held there. To set the endpoint hold for a channel you need to get into the options menu (Func 9, both pushbuttons down while powering up) and then set the endpoint hold function on each channel you wish it enabled on. Once you have done this you can exit the option menu and adjust the servos on those channels.
ORIGINAL: skysfallin
I am attempting to set up my servos on an EQ6 and it is frustrating the crap out of me. This is a 40% airplane with multiple servos on all surfaces. I am trying to set the centers and end points on all the servos. I can get the centers adjusted but can not get the srevos to move to the endpoint hold and stay there so I can adjust enpoint travel. The directions say to turn on endpoint hold, how do you turn that function on. Help!
