ORIGINAL: steed2
Lowering the arm will decrease leverage and decrease stopping power, but the will come on faster.
Thanks for the replyI want to ensure I understand you here. By lowing the arm (right side of the picture) it will DECREASE stopping powe....but the brakes will be applied faster?
ORIGINAL: steed2
Search the ofna linkage mod and do it, it will solve so many issues for you.
Thanks, I just checked this out and it looks very interesting indeed. Seems I'm not the only Savage owner with braking issues.
ORIGINAL: steed2
If not, replace the spring with fuel tubing and adjust the brakes with the adjuster wheel on the end of the rod. Also the factory servo is quite weak.
I think (in order) Iwill try the following:
1. Replace spring with fuel tube. How long? 2"???
2. Try the 'OFNA linkage' mod
3. Upgrade servo with more torque.
Thanks!
