ORIGINAL: ahicks
I think so too!
I went to the owners manual and found a couple tid-bits that interested me. I'm sure there's also much more for sure! It's 72 pages!
suggested prop after break in 12x6
rod is bushed, so they're asking to run a 20:1 gas/oil mix
I didn't look thoroughly, but didn't see who was supplying the ign. module. They do mention it's smaller to allow use with the planes that the engine is designed to be used on, and set to use from 4.8v to 8.4, mentioning specifically no need for regulation on Life or LiPo to a maximum of 8.4 volts. Sounds like a nice module!
Ignition ? RCEXL A02 module for next generation gas little engines and 4.8-8.4 input voltage , like all A02 new versions.
Best regards
