ORIGINAL: deep sky
i just looked at 60 pix of you captains boats and what i dont see is the antana im geting ready to install my recever where are you captains puting it ? under the deck i was thinking of running it up the radar mast or puting it up as a vaf on the side like big d what do you think
Currently I run it through the owners cabin hatch and then loop it through a hole that is drilled on the back of the mast platform. This spot will eventually be where the light pole will go. At some point I am going to drill a hole on the deck and have a plastic straw come through the deck. This is where I will feed the antenna wire and then it will clip onto the light pole.
I hope this helps.
-Rich.
