RE: Shark 650EP Boat
This is my idea and a suggestion! I would move motor toward the flex cable about 1/2" which depends on lenght of coupler. Use a dremel to cut flex cable but be careful not to cut off to much, small incruments at a time is best. Been there, done that. That cooling jacket should be replaced as it doesn't cover much of motor. Just trying to make sure that problems are few and far between. You'll be alright with Husky on board, he's a Guru, as far as i'm concerned. Any other thoughts , bring'em on board.
